KEYED 12+ under hood 85 regal v6
usetaboost
SAY CAR RAMROD!!
Are there any useless emission connectors that have keyed 12v under the hood? Only thing I have left to wire up on the electric fans and would rather use something existing under the hood. The smog pump is long gone and so is the electric heat plate under the carb. Thought I would see what everyone is using before I go through the trouble of running a wire from inside.
I used the keyed hot for the wiper motor. I pulled one of the metal tabs out of the plastic connector and soldered a wire to it. The opening in the back of the connector is plenty big for two wires. I used that to trigger a relay for the electric fans.
