Kirban DP
87Turbo-TWE4
Has anybody used one of these DP's or had any experience with them? I need a DP but can't afford $400+. If it works good that would be fine with me.
Yep, got one on my car. love it . I ported and polished my exhaust elbow. I did a lot more to mine than they recommended. As much as I cut out of that thing, it has to flow nearly as good as a THDP.
No, other than it is a slow process tightening the bolts up under the elbow. The bolts that come with it are allen head bolts. You will have to cut off the allen wrench real short in order to tighten. Not hard at all to do. I also made my catalytic converter pipe a 3" inlet.
I had one on my car fit perfect.Once I had it installed and all clamped in I removed it and had the 2 pieces welded together.:D I thought the clamp looked like crap.I think if I did it again I would have ported the elbow and opened up the puck a little.It fit better than some of the other DP's I have seen.
Kevin
