Knock at WOT help!!
boost86
TPS .44
IAC 20
AF 05
L8 38
INT 135
BL 144
CLT 179
ATS 88
RPM 750-800
38 fuel PSi at line on idling
42-43 fuel PSI at line off idling
2.1 scanmaster
translator info
base setting 3" sensor
WOT setting at 2 4% rich
GN 5.2 MAF
I get excessive knock when i try to really get into the car. Especially WOT....have seen the scanmaster show as high as 15 or so on the knock. Of course, i let out as soon as this is seen. But what else coudl be causing this??? Car had 93 before and now has small amount of 92 in it. Boost set at 15psi.....chipped for 93 octane.
Help?
All reading were at idle car at full temp.
