Knock issues solved !
insane6
I have been fighting knock for a long time and Good news I found the problem , Jdfastgn suggested to check reluctor wheel and confirm that it has not spun , once i got the balancer off the reluctor wheel was off by
.069 inches compared to the other balancer in my attic, but what I found is the balancer was cracked all the way down along the key way ! Install the new balancer and with the chip as Eric sent it and at 25.7 boost A\F set 10.8, pump gas and alky and 90 degree weather , it is pulling like a freight train and NO KNOCK !! after the run it showed pulling 5% fuel
Just wanted every one to know maybe could help someone else
The Bolt on the crank was not tight enough .make sure you torque that down good !
usally I do get tight ,but won't lie I have alway used impact gun and locktite , but never did the 200 # suggested
