knock retard or knock count
Warped
No helmet required!
If less than 2* of knock retard at the gear change is reasonable, does the actual knock count matter?
If 2* of knock retard is not reasonable, and you tune it to no knock retard but still have some knock count, does that matter?
Will that 2* of knock retard ultimately lead to a problem?
I can pull out that 2* with the translator starting at 3200 rpm. Would that be the best approach or should I just let the computer pull it out if it detects knock?
Thanks.
