Thanks Guys.
Reset the FP using the Snap On Gauge. Holding steady at 43 off vac, and 38/39 on. (although it was high at first). THought about putting the stock FPR back on just to see if there were any differences, but I guess if I'm holding at 43 and 38/39, not point in doing that?
Took various runs/pulls, and still recording knock, although nothing as high as the double digits I was seeing previously. Interestingly, on 2 separate occasions, I was recording about 5-6* of knock retard while at 8-11# of boost. But under WOT with 16# of boost (I know, probably not the best idea), the readings were 2.3 and 1.8 respectively. Holding it steady does not result in the knock increasing. Is there any reason why the knock would be worse at 8# vs 16#? Or maybe its just coincidence.
FP is rising 1:1 with boost, so I guess that's good.
Went to Island Dragway (here in NJ) with the intent of buying some race gas. Didn't have time to stay there until they opened (3 hours after I got there), but talked to a racer who says they do sell the Sunoco 104 Octane (unleaded) right outta the pump. But alas, had prior engagements and had to leave.
I also found a place about 20 miles from me that sells 5 gallon containers of Sunoco 260GT. Supposedly he has it in stock, available for purchase at about $9 a gallon. Phuck it - if he has it on Monday morning when I head over there, I'll buy it.
VtheGN - No disrespect taken. I welcome all suggestions, and who knows, maybe I did get some bad gas or put the mid grade in while not paying attention. I was low on fuel today (little less than a quarter), so I went and put Sunoco 93 in, about 8 gallons. Figure I'll leave some room for the race gas if I can find it.
I mentioned in an earlier post that I need a new belt pulley tensioner. You can absolutely hear it rattle around, although its intermittent. But definitely there. Is there any chance that when I'm putting a load on the engine, the noise coming from the bearings/tensioner is being detected as knock?
