achalmersman
- May 28, 2012
that is why I said under WOT if it does not drop. I'm just trying to save the guy some trouble.If the strainers are jacked up and restricted he could have good pressure at idle but as the need for more fuel is there the restriction won't allow it. Just like having a jacked up filter. He saw a big difference when changing the filter and I bet he will be seeing the same junk in the tank. I have stock coils on my gn as many do and have been mid 10's with more left in it....it's not his coils. I would have found a cheapo fuel pressure gauge that can be temporarily routed where he can see it and when all the issues are there he will see fuel pressure dropping a lot. Wish you were near me cause this would be fixed in a quickness.
If he puts a fuel pressure gauge on the windshield so that he can read it while driving and while running WOT the pressure does not drop (do this several times while duplicating the problem) there is no "volume" problem. This is very basic drivability troubleshooting.
