Last night a night I will never forget
Yea I hate to slow it down but I have no choice to finish out the season. Then I will make my decision to add to this car or build another car?? I am going to add timing and work on my 60ft times this weekend. I am going to put the big slicks back on for nex't weekend at US41:) I should pick up mph for sure. The car loves about 25lbs of boost but it creeps up in the 29-30 range towards the end of the 1/4 passes. No spark knock though:) I use 112-116 racing fuel. I take no chances. It you cannot afford the gas you need to sell the car!
What kind of setup do you have for your wastegate?
Ted, Cliff and Bison
I am not sure about another record? Maybe another fast MPH or ET stock block, Iron heads,factory rods and Only a PT70? Maybe because it is being done with the factory ecm:biggrin: I have a internal wastegate with low psi spring. I need to be able to stage the car after pre stagging both lights on then start building boost until a 10-12 setting let off the button and go to 25lbs top end. Get my point? Thanks for caring:)
