Turbo1dr
9 Sec Wanna-Be
- May 25, 2001
This thread shows how I installed a late model Buick gauge cluster in my 1987 Buick Turbo Regal. The factory gauge cluster was very bad with only a large rectangular speedometer, a fuel gauge and a LED bar graph tach and boost gauge. VERY BORING for such a high performance car.
Below are the list of parts that I used to create this conversion. Not all steps or details are covered since custom fabrication is always time consuming. Remember to test fit the part many, many times so it will come out looking great and so you won't screw up too much...hahaha! So, lets get started!
This is what you'll need.
1. Gauge cluster along with 8" of the harness plug from a 92-93 LeSabre.
2. The "information center" that is located on top of the dash (same car).
3. 4 wire oil pressure sender with harness connector (same car)
4. 3 wire temperature sender/sensor with harness connector (same car)
5. Light green speed sensor buffer with connectors from a mid 80's GM car.
6. Speedometer head from a early to mid 80s GM car.
7. Three "C1" Cluster harness connector terminals from a bone yard or new ones.
8. Small piece of 1/4" Plexiglas about 2"x3" or other material for fabricating a speed sensor mount.
9. 470 Ohm resistor from Radio Shack or the one from your original alternator light bulb socket. I'd just go buy one and save your original.
10. Brown wire, Green wire and white wire or just any colored wire you choose. Color coded salvage yard wires will work too!
11. Caspers Electronics C1 harness adaptor.
Misc...
Soldering gun, additional color coded wires, heat shrink wrap, 3 idiot lights bulbs & sockets for the BRAKE, CRUISE and FASTEN BELT lights and some sort of adhesive like JB Weld or "hot glue".
Misc...
