Originally posted by TurboDiverArt
Call Conley's, they sell a kit. Comes with an additional boost controller and an electric control valve, fittings and lines. No reason to mount a separate gate, just need 2 controllers (one set for launch boost and the other for max boost) and a way to control which one sends pressure to the wastegate. I use one, works great, no worry about building boost. Pull into the staging lights, hit trans brake and put foot to the floor.
Personally I don't think you need a rev limiter. I think this would bounce the boost all over the place as the turbo would keep gaining and losing exhaust pressure. Just use the boost launch kit. You can also buy the innovative controller which has it built in as well. I think many people are using this with very good and consistent results.
