Built two different 82-92 Camaro's.
Both stock block,crank,rods,intake.
JE pistons and steel caps.
.72mm turbo front mount on both.
South side lift bars and connectors for rear suspension along with coil overs and alot of home made pcs and experiments ending with the final design.
Love this body style and this engine.
Results:
1.48 60' leaving the line with 6psi on pump gas through the mufflers on DOT. Tire. 10.92@124mph. 3350lbs.
Be glad to help if you decide to go with this body style...
~Scott
