LC2 in 2nd or 3rd gen. F- Body
ronbuick
Who has done this??, I'm considering buying one of these for a new project, would like to talk about this, I will need some info.
Ron
Built two different 82-92 Camaro's.
Both stock block,crank,rods,intake.
JE pistons and steel caps.
.72mm turbo front mount on both.
South side lift bars and connectors for rear suspension along with coil overs and alot of home made pcs and experiments ending with the final design.
Love this body style and this engine.
Results:
1.48 60' leaving the line with 6psi on pump gas through the mufflers on DOT. Tire. 10.92@124mph. 3350lbs.
Be glad to help if you decide to go with this body style...
~Scott
Thanks for the info, I will be picking a 86T/A in Medford, Or. in a couple of weeks and I would like to follow thru of this project and I would like to talk with ya about this.
thanks
Ron
208-365-3653days
