I just put my new motor in my 87 GN and I am having a problem with the numbers 1,5,6 cyl runing lean. I noticed when I was triing to break the cam in the tubes on the headers for those cyl where glowing after only about 4 min at 2000 rpm. When I pulled the pluges on those cyl they looked like I had just taken them out of the box, I noticed the same thing on the plugs out of the old motor. I put new 65# injectors in the new motor so I now that it is not the injectors. Everything else electronics wise is the same as the setup on the old motor. Any help would be great, thanks David.
