87Limited2Turbo
- Feb 16, 2010
Just got my motor back up and running. at idle after when warm about every 30 to 40 seconds it gets a slight cough and idle goes up slightly for about 5 seconds and then drops back to normal (750-775). when moving it runs great during normal acceleration and even if i get on it a little its fine. but if i stand on it it coughs. i have turbotweak 5.6 with 36lbrs (bluetop) boost set at 10-11 lbs. blms at idle are around 124 but the higher the throttle goes the blm drops, about 119 at the lowest. earlier i raised the boost to 14 lbs and its now smoother but stills coughs. dont have a PL log just yet but will tomorrow. during all this i have gotten a few knock counts (7 is highest ive seen) but i have yet to see any knock retard.
idle
iac- about 18
tps- .42
my questions are these:
1. my papers with chip states max boost 16-18 lbs. do i need to run boost in that range ? thought maybe the fuel was set for that amout of boost. cause as i stated when i raise boost its getting smoother. should i reset the ecm and let it learn again with new boost settings ?
2. dont remember the exact spark timing but when i get on the throttle the spark timing goes wide open and stays there til i get off the throttle. is this normal ?
idle
iac- about 18
tps- .42
