I've got an interesting problem. Put the car away in the shop for the winter. Car was runninig OK when I parked it. Over the winter I did some brake work and I just pulled the transmission to change the converter. Got that done and went to start the car to bring trans fluid up to level and "IT WOULDN'T START."
Looked at the XFI box; power lite is on as well as cam & crank
The LED's for the injectors all come on but they do not blink sequentially like they should while cranking. They all are on constantly. What would cause this, as this seems to indicate that this is the area of problem.
I'm pretty sure I didn't screw any wiring up ... I don't think
I have 43 lbs. fuel pressure while cranking.
Because it was starting and running fine when I parked it, It would seem that the problem should be be attributed to something I've done .. but what ?
Any help would be appreciated,
Thanks,
George
Thanks,
George
