Leftover parts from engine partout
RED LS1
SENIOR MEMBER
1. Turbonetics CPT-66. All polished in great condition. Older turbo but miles are very low. No funny shaft play. Makes mid 10 power on the right motor. Comes all set up with Turbonetics RG45 Wastegate ($420 new) also polished and extremely low miles. $700 shipped!
2. Crank and water pump pullies painted nice and in great shape. $95 shipped.
3. Stock piston set. 1 piston broke but comes with 1 extra correct piston and rod so 7 total. $ 95 shipped.
4. Stock Valve covers with newer paint. also have Metco breathers $99 shipped.
5. Full Buick V6 hardware kit. $150 shipped. Includes the following.
oil pan
Oil pickup tube
ARP Rod bolts
Flexplate
ARP main studs
ARP head bolts
motor mount Block & Frame
Coil pack nuts and bolt
cable bracket screws and clip
Alt Stud with loop for strap (can throw in ratchet strap)
oil return bolts
Turbo Flange nuts
Rocker stud bolts
Starter shield screws
converter bolts for 9.5 inch
Bell housing bolts
2 Cam bolts
Cam button/spring
crank metal thin shield
Exhaust manifold studs
Intake bolts
all misc intake hardware IE: Fuel Rail, EGR Hold down, studs, nuts
Water pump hardware
Timing cover hardware with correct starter wire studs
ACCSSY bracket bolts
Valve cover studs
Plenum bolts
Cam sensor hold down bolt
Crank pulley
water pump pulley
Down pipe to Turbo bolts
Plastic timing tab
6. Stock Rocker shafts. $45 shipped
I also have Brackets that mount from headers to the alt, Coil pack brackets, alternator, starter, AC pump and all AC stuff, condenser, and more....
Interested in selling the turbo without the wastegate? I just installed a new Turbosmart Hypergate 45mm on my downpipe.
Bryan
If you mean Intercooler bracket that stuff is long gone. It has a front mount.
