Lets Talk Trans Coolers
Here's the transmission cooler set up I have installed in my car. I was lucky enough to be able to snag one of these kits years ago when Byron had these available.
This transmission cooler set up came with a custom CNC mounting bracket (powder coated) & utilizes 5/16" inverted flare connections on hoses for a real professional / clean & tidy looking installation.
I installed it in conjunction with a new Aluminum Alradco Radiator and a bottle of Lubeguard Platinum and all I can say is WoW! My engine coolant and transmission fluid temperatures are a thing of the past!
https://www.turbobuick.com/threads/...-street-strip-kit-period.355975/#post-2847436
http://www.lubegard.com/~/C-113/LUBEGARD+Platinum+High+Performance+ATF+Protectant
http://www.lubegard.com/pdfs/LG_Platinum_sell_sheet7.pdf
I've always used the big
howdy guys
I would like to know what you small non lock converter guys are running for trans coolers.....
I seem to be having a problem with fluid being blown out of the overflow tube on the top of the trans..
My current cooler is a tube and fin type thats 7X14 3/4 inch thick.. Its located if front of the radiator/a/c stack up. The RJC intercooler is in front of it. i have dual fans
I dynoed the car to see if i could find out where the fluid is coming from and its from the overflow. I have this same problem on the street and the track too.
The pan temp was 140 degrees the center of the case was 185 . The convertor was 241 degrees.
The convertor is a PTC 17 blade 9.5 inch..
Thansk for the help
I've always used the largest B&M stacked plate tranny cooler that summit sells with great results... even after sitting on the tranny brake for an extended time the fluid temps were always back down to a manageable temp by the time I got back to my pit spot.
Turbo6inKY-
Did you ever take the tranny fluid out of the radiator?
Did you wind up getting a new water pump?
