howdy guys
I would like to know what you small non lock converter guys are running for trans coolers.....
I seem to be having a problem with fluid being blown out of the overflow tube on the top of the trans..
My current cooler is a tube and fin type thats 7X14 3/4 inch thick.. Its located if front of the radiator/a/c stack up. The RJC intercooler is in front of it. i have dual fans
I dynoed the car to see if i could find out where the fluid is coming from and its from the overflow. I have this same problem on the street and the track too.
The pan temp was 140 degrees the center of the case was 185 . The convertor was 241 degrees.
The convertor is a PTC 17 blade 9.5 inch..
Thansk for the help
Thansk for the help
