level 10 help
cold85
i just bought a car and the guy had level 10 redo the trans with 3500 stall.
the problem is the car hit very hard going into gears and it too hard for the street and it hits very hard downshifting at low rpms and if i barely touch the gas at cruise it drops down a gear to quick so it is in and out of 3 & 4th at cruise.
based on your description it souns as if the tv cable is adjusted too tight.try to loosen the setting 5 clicks and see what happens
