excobraguy
- Feb 25, 2007
My new engine has a bad lifter tapping, so bad I took the intake off and swapped the lifters thinking the new ones might be gunked up with packing grease. This is a Revolution X roller cam by the way.
When I pulled the lifters I noticed that #6 intake would go down about 90% off the way and then "stick". You could always push it the rest of the way down with a little pressure. After putting in the new lifters I have the exact same tapping noise as before, it is coming from #6 again. Here is my question....is it possible to ball hone a lifter bore with the engine installed??? It has to be a very fine amount to be removed that is making the lifter stick. Also, is it possible that an overbored lifter bore can cause the lifter to slide "sideways" and stick? I need help on this one for sure!!!!! Looking for all helpful input.............thanks guys. :smile:
Oh, one other thing.....would driving it like this cause the lifter to slap against the cam and beat the cam lobe down?????
