lifter preload
87-TURBO-T
got my new pushrods today. i'm showing about .040 preload. is that ok? flat tappet cam. thanks
Go with .040 or get customs.
You will need to research but can you shim the rocker shaft assembly allowing you to use the .040's but get the preload down to .025? Of course you have the option to go with a set of T&D's or Harland Sharp's adjustable but that is about $500.
