I recently just put my car all back together, and there was a very clear ticking sound..at first i figure exhaust leaks so i pulled them off checked for cracks and then had them checked to see if they were warped..after getting them fixed i put it back together and the tick was gone. ( i figured problem solved) not the case. once the car got to its normal temps about 150. the tick came back.
im guessing its a lifter based on this
it only does it when the car warms up, and it only does it cruising around. it seems to go away when i get into it, or go WOT. (the oil psi is 25 at operating temp and idle, and 50 at wot)
other then that i cant think of anything else.
its seen 2 oil changes already and doesnt have more then 300km since its been back out.
ive also localized the tick to the back 2 passenger side cylinders.
am i right..or is there something else i should be looking at?
oh ya..the heads are completely stock
