Oil is new, 6 qts. in the stock pan.My plunger in my oil pump stuck and i removed oil pump housing and got it out, I put in a new one and repacked the pump and started it and got 65-70 psi. Then when it warms up i get 12-15 psi at idle, and it goes up and down due to rpm level as well. Lifters dont tick during  higher oil pressure  but do when i decrease rpm. Do i need one of the bigger springs that came with my kit? Or is it my pump housing or plunger again?
