Any one know what this light blue goo scammer stuff is coming out the gasket area of the coil pack? thanks in advance.
tgamino@yahoo.com
tgamino@yahoo.com
SignUp Now!never good! Sounds like your ignition module is on it's way out.
tgamino@yahoo.com
if its still works don't worry about it---------it can be a sign of a leaking gasket between the coilpac and ignition module and a replacement of that gasket will cure it easily----------if on the other hand it is not working it really doesn't matter--------get a new one----------the blue goo is a sealant used to moisture proof the ignition module and can get soft in long use and hot days and will harden if cooled but if the gasket is bad it will leak--------- or in the event of electrical failure of an internal component----------many of the ignition packs did not use the blue goo...................RC
Richard, my blue goo never did harden upon cooling to RmTmp & even cold-flowed/emptied most of it's sealant goo when I placed it (tilted) in a box/bag to take to AZone for ck-out...
