Limit Engineering TE45a
turbov6joe
Signal 1 J-12
I have a John Craig (Limit Engineering) TE45a with a PT&E .63 a/r exhaust housing for sale. Turbo has less than 1000 miles.... no smoke or abnormal shaft play. Turbo comes with a heavy duty wastegate and is ported for a THDP. No damage or discoloration. $780.00 + shipping
In case your not aware, this turbo is a big shaft turbo and sells for $1100.00 new from anyone plus another $80.00 for the HD wastegate. It is capable of easy 10 second time slips with the right combo.
Can you send pics to datarjowon@hotmail.com. What kind of stall were you using with this turbo? I am using an ATR downpipe...do you know if the porting you have done will match my downpipe puck? I think the puck on mine is 1.5". Thanks
I use a 3600-3800 stall #6 pump Precision Vigilante. I'm pretty sure that the THDP uses the same size puck as the ATR, not a problem there. As for pics, I have none. Like I said in the ad, there are no physical blemishes to look at....looks almost like it did the day I got it. I have a potential local buyer coming to look at it tonight....sale pending. If the sale falls through I'll post.
