youll need to swap out pistons /rods ,should be ok with crank the std NA crank differs from the turbo crank in that its not radiused but some have used the N/A inplace of the radiused turbo crank on intercooled setups and done ok ,
bolt on intake and turbo exhaust manifolds , coilpack
add sensors and balancer with crank ring, , install wiring harnesses
add highpressure fuel feed line and return , turbo fuel tank/sender, good fuel pump,
you dont need the turbo dash cluster, its just a light show
if you keep it totally stock you might be ok , if you start modding and dont upgrade tranny and rear expect breakage
gearing in the limited's 7.5 "will be low like 2.52 so unless you have the 3.42 8.5 " from the turbo car dont expect much performance from it
