xrunner123
- Oct 2, 2002
Hi,
I installed the B&M 46075 Launch Control Solenoid on the rear line coming out of the mc but when energized it still allows pressure to the rear brakes.
I disconnected the output and piped it to a clear pipe to see what it's doing. When energized and lightly pressing the brakes it holds but when I press on the pedal harder it does squirt by. I also tried installing it backwards same thing. I though it was a bad unit so I returned it and got another one. Same thing.
Is this normal? Are you supposed to just tap and not slam the brake pedal?
