I'am getting a little puff of black smoke on full throttle turbo operation & then goes right away during full turbo acceleration. If I floor it again the second or more times right away there is no initial puff of smoke at all. Is this just unburnt fuel built up in the intake chambers from non turbo use while highway cruising? The engine seems to run quite low rpms when the trany is in overdrive lock-up . The entire engine ,turbo,carb/everything are completly restored to stock and seems to run perfectly with tons of turbo power except for this little puff of smoke now and then.The carb metering and power settings are all set to specs.
Bob
Bob
