Lock-up convertor with a FAST system B2B
SloGN
I'm a ASSHOLE.....
hey guys
I have recently swapped out my stock ECM for a Fast B2B unit. now that i have done that i have lost the ability for the ecm to lock -up the converter when it goes into 4th gear.
I have done the manual switch thru the aldl connector.
What i want to know is if there is a way that i can have the convertor lock-up when it goes into 4th gear only. Also hope that there is a way that i can override that also. so if i goes racing that it will not lock the convertor when racing
the maual switch thing works ok but sometimes i forget to unlock the converter and then it lugs and bangs gears when shifting.
I'm not familiar with the FAST B2B, but I can't believe an aftermarket ECM would not have the ability to provide TCC control. I know the FAST XFI can be setup to control TCC.
First gen fast B2B does not have T.C.lock up,I'm using B&M converter lock up box works great you can set lock up for any speed you want.HTH.
Yes the B&M box worsk but not as well as the TCC1 unit from digital horsepower. I love mine, and i will using it for other purposes.
