Jan 14, 2007 #1 W wahoo50 Member Joined Sep 4, 2002 Messages 153 Am installing a torque converter lockup switch which I plan to wire to the data port, can someone advise which terminals to connect to? Can't find a diagram that explains what each terminal is for.
Jan 14, 2007 #2 M mikestertwo Well-Known Member Joined Sep 13, 2006 Messages 5,249 "A" to "F" on your ALDL connector. "A" is ground, "F" is the TCC solenoid.
Jan 14, 2007 #3 W wahoo50 Member Joined Sep 4, 2002 Messages 153 how do I determine which is 'A' and which is 'F'? Thanks so much for the reply.
Jan 14, 2007 #4 gsgns4me Member Joined Aug 13, 2006 Messages 542 wahoo50 said: how do I determine which is 'A' and which is 'F'? Thanks so much for the reply. Click to expand... Maybe this will help. Disregard the "red" part of the image.......
Jan 14, 2007 #5 W wahoo50 Member Joined Sep 4, 2002 Messages 153 Outstanding Dwayne. Thank you. So in order to lock the converter I simply connect A to F through a switch?
Jan 14, 2007 #6 gsgns4me Member Joined Aug 13, 2006 Messages 542 wahoo50 said: Outstanding Dwayne. Thank you. So in order to lock the converter I simply connect A to F through a switch? Click to expand... Yes. Or just use "F" and any good ground.
