Logging fuel pressure with powerlogger?
mtocrs1
Mtocrs1
What fuel pressure sender/transducer do you guys use and where can they be purchased? How do you guys hook them up to the fuel rail? Does someone sell a fitting that works good?
I used this (Jegs110526)
How did you hook this up? Do you need an adaptor for the powerlogger to hook into? Does this screw into the rail?. Got any pics of the setup?
I removed the fuel rail schraeder valve and threaded the adapter onto the rail fitting. You need the AN cap that goes on the end as well. I used a few 1/8" stainless nipples and a stainless elbow to attach the transducer to the adapter.
