Longer intake manifold bolt goes where????
boosted84
i forgot to mark which intake manifold bolts went where now i cant remember where the longer bolt goes anyone know where as in drivers or passengers side and how many from front
thanks in advance
I don't remember the exact positions but I can tell you they go wherever there is an accessory that bolts on. (like the hoisting point)
I should know this I just took mine off. The one with the nut is up on the front pass side for the pull hook like BlackBandit said I belive there is another one in the back driver side for the EGR sol mounting?
Easy to tell. The one with the 10mm stud is the front one for the hook and the one with the 8mm stud is for the EGR solenoid bracket.
Hey turbofish...any idea where we can get studs of this kind in different sizes and/or lengths??
Bob K
Bob K
Since he works with Brian now they should have buckets of them. I put a stud & hook front & back corners for install then just take the hooks off until needed again.
I dont see any studs there??
He's got them and he's got kits for everything. I've bought tons of bolts and studs off him. e-mail him like I stated and tell him what your looking for and he will e-mail you back what he's got. He has everything from stock to polished stainless steel and everything in between.
