Lookig for a radiator
Farmer
I'm having to replace my timing chain and water pump. I want to put a new radiator in. Nothing fancy but aluminum. Can anyone give me a recommendation on a reasonably pieced one and where to get it. The timing gear and water pump are from TA but their radiators are more than I want to spend.
OK, cool. I found something that should work for me. 2 row with 1 inch tubes that will fit with my shroud, all aluminum at $200.
You could also try the f-body radiator if you don't mind losing the oil cooler. It's a cheap alternative .
We don't have oil coolers.
The f-body radiator is wider than the stock radiator. It won't fit the stock shroud. Good choice if moving to an electric fan though.
