-how do you base line on pump gas or race gas
How would you baseline without? Answer this. You have your answer how to with.
-where should you start with timing..what is to much timing.could someone post there timing curve (LT1)
Where would you start without alky. Answer this...
-should the AFR stay at 11.8-12.1 on any fuel
That is the typical target. What your combination may ultimately like.. my LT1 crystal ball is broken
-what are things to look for (BAD)
Knock
-is a egt meter a good tool and where do you like to see it...#
Depends where its placed in the exhuast. Run the car with 100+octane and get your basline EGT. Then drop octane and run alcohol. EGT on alky will be slightly lower. Use your WB to set your AF ratio. EGT will spike with knock activity.
-what are the pro's & con's
Pro's... higher boost, higher timing, cheaper gas, cooling, even out combustion, stop detonation, etc.
Cons.. running out. Improper design of system.
-what are things NOT to do
Run out of alcohol, dont run high volumes of water, dont use cheap lines, cheap activation switches, cheap componenets trying to save a buck. It will come back at you with a vengenance.
-what are thing to do..
Learn how to tune your motor. Learn how to read plugs, learn how to tell spark knock is occurring, Learn to monitor whats happening and why. Summary.. educate yourself.
HTH
