Loose Pulley
spierson1337
Hi all,
Easiest thing to do is see this video (86 T-Type)
I have a loose pulley that's causing a ton of noise to come from the engine bay. It doesn't seem that the rusty bolts up front are loose, I'm able to wiggle the entire pulley. Not sure if maybe a bearing wore out or if there is a loose bolt around the back somewhere. Any ideas on how to tighten this down? Thanks!
Yeah...new waterpump and 4 new bolts. In order for it to not be the bearing, the entire pump would either be loose or cracked...either way, it would be leaking.
And don't forget to put sealant on the 4 long bolts when you swap the water pump, they hit water.
