Freddie's Buick
Hell No! I'm not a junior
- Jan 3, 2002
Well,
I'm giving up on the '81 ECM. It seems that this model year ECM is just a basic emissions control mechanism.
I' ve tried all the settings on the TPS, put in a new ECM, went back to a 160 degree thermostat and my problem remains. My next step would be a Hyper-chip.
A chip goes for well over a $100.00 and I am not convinced that this would make much of a change. Going retro seems to cost less. (And you guys pretty much know how cheap I am by now so that's were I'm headed).
Here's the problem:
(This only happens when the engine is well run and at peak operating temperture). Something causes knocking at every shift change. This is detonation and the rattle I hate. (And it ain't cheap gas because I only use 93 octane Chevron).
If I remove the Distributor EST plug the knocking at shift change stops. But by running it this way the timing will not advance when one throttles up. So it is a slow crawl.
Going retro would be a possible solution. I've got the Pre-EST/HEI distributor and a pre-EST non-TPS Q-jet that I have to soop up some. All that is left to deal with now is the TCC. Once I'm done I'll give an update.
I tried this once before and noticed that the EST set-up was better, but this was before I had all the mods I have now.
We'll see what happens...... :cool
Here's the problem:
