LOT of oil coming from my wastegate!!!!!!!!
GNICETRY
Cat&wife post starter
I'm really starting not to like my car. Look under the hood and see lots of oil near my wastegate. The little filter isn't on it either, but I don't think that it would help anyway. It looks like it is coming out with some pressure becasue it looks like spot/drops are all over that area. Change the wastegate??? I need this to stop, smells like $hit too.:mad: :mad:
The only way that any oil would be coming from the wastegate is if the Turbo is blowing it out. Pull off your boost like Y, and see if it is filled with oil.
Does the car smoke at all?
Maybe the grommit in the front of you passenger valve cover is leaking?
How many miles on the engine?
What kind of turbo?
How many miles on the turbo?
I spoke with John Craig and checked my turbo, it is good. He suggested that I Check my whole PCV system. So I put in new PCV and check valve and noticed that my old checkvalve was sticking. Have yet to test it yet.
