Lots and Lots of Parts that need to go BYE BYE!!!
jdpolzin
SENSORS, SWITCHES, SOLENOIDS, ELECTRICAL:
1. IAC Valves ( known good) $20 each
2. Dimmer switches (4, known good) $5 each
3. Headlight Switches (3, known good) $8 each
4. Defrost Switches (2, known good) $8 each
5. Relays $2 each
6. AC Pressure Switches $3 each
7. EGR solenoids (4, known good) $10 each
8. Antenna relays $5 each
9. Vapor Canister Solenoid (2, known good) $5
10. Chime Box (6 pin) $12
11.
12.
13. Trunk Lights (3) $5 each
14. Oil Pressure Senders (4) $2 each
15. Coolant temp Sensors (used, known good) $5 each
16. Coolant switch (dummy light, used) $5 each
17. OE Fuel pump Resonators (used) $5 each
ENGINE, ENGINE BAY:
1. 109 block $300
2. 5 stock rods $25 all
3. oil slingers (6) $5 each
4. Oil Filter Housings (3) $8 each
5. Adjustable Wastegate Actuator (Heavy Duty, almost new, nice) $45
6. Stock Wastegate Actuators (3) $15
7. IC Brackets (either side) $20 each
8. Entire stock IC set up (IC, fan, both brackets, IC shroud) $125
9. HydroBoost Line (Booster to gear box) $10
10. Hot Air TV cable $25
11. Turbo oil feed (2) $10 each
12. Brass Oil feed adapter (4) $10 each
13. Turbo oil drain back tube $35
14. Turbo oil drain back brass fitting $10
15. Valve Cover Vent (passenger side, stock whole set up with turbo bell) $30
16. OE Radiator Caps (3) $5 each
17.
18. Fuel Lines (rail to frame, set) $50
19. Fuel Rail (3) $30 each
20. Stock Fuel pressure Regulator (2) $5 each
21. Tensioner Pulley (2) $8 each
22. AC Compressor "Y" Bracket (front of AC to Alternator, flat) $15
23. Hot Air oil fill tube $15
24. Stock Fuel Pressure Regulator Vaccum hoses (4) $5 each
25. Crank Sensor w/bracket $30
26. New lifters (flat tappet, Speed Pro, 16) $40 set
27. TRW Wrist Pins $15 set
28. Factory Air filter Box $30
29. Complete Factory Air Intake (air box, bracket, inlet, hose, elbow) $100
30. Coil pack and Ignition Module $100
31. Valve Covers (stock drivers side, 3) $10 each
32. NEW Rod Bearings (Michigan 20 under) $10
33. Accessories Bracket $40
34.Speed Pro 10499 20 over Rings NEW $50
35. Power Steering pump $60
36. PS to Gear box line $15
37. Ported Stock DP Elbow $30
38. Used but good Water pumps (3) $5 each
39. High Volume Oil Pump Kit (installed but not ran, with new gaskets, complete kit) $20
40. Coil Pack flat mounting plate $15
41. Coolant hose set (complete set, not radiator) $30
42.
43. Balancer Hub Bolt and Washer (7) $2 each
44. 1/4" Valve cover spacers $20
45. Valley pan baffle $35
46. Timing Chain (aftermarket, stock style) $10
47. Crank Sensor Bracket $6
48. Turbo Sheild (rear, the small one) $8
49. Heater Control Valves (2, used) $10 each
50. N/A Balancer (no reluctor ring) $8
51. AC Compressor (2, used in nice shape) $60 each
52. MAF Mounting Bracket (aftermarket, for use without the stock air box) $15
53. AC Evaporater Bushings (uppers and lowers) $3 each
54. Headers w/crossover (welded) $150 set
55. Oil Fill Cap (OE, 86-87) $15
56. Up Pipe $15
INJECTORS:
1. 36# blue tops with ATR chip (NEW) $150
2. Stock low mile Injectors with stock chip $50
3. 40# Green tops with ATR chip (used, known good) $150
TRANSMISSION:
1. 200r4 CZF Core (complete) $250
2. 200r4 cable bracket (floor shift, bracket that the cable moves on trans) $40
3. TH350 shift cable $15
4. Trans to Engine block bolts $5 set
5. NOS GN Governor (orange gear) $200
6. Speedo gear and housing (3.42) $20
7. 200r4 crossmember $50
8. Trans Mount (used, 1 year old) $5
9. Crossmember bushings (used, crossmember to frame) $5 set both sides
10. Mounting Clip (for wire harness to attach to trans) $5
BRAKES:
1. Baer Brakes (NEW, Rear, Ford 9", IronSport) $450
2. HydroBoost Line (booster to gear box) $10
3. Brake line (Master to prop valve) $5
OTHER, BODY, INTERIOR, CHASSIS:
1. Stock Lower rear Control Arms (new bushings, nice) $50
2. Rear Carpet inserts (grey, 87 T) $10
3. Seat belt bolt caps (grey, cover the hole for the seatbelt bolts) $5 each
4. Chrome Windsheild Trim (two sides, no top) $10 each
5. ECM box/kick panel (grey) $20
6. Swaybar bushings (NEW, Energy Suspension 9.5108G) $15
7. Front Springs (NEW, MOOG 5608) $50
8.
9. Coil Spring Isolators $5 each
10. Antenna Nut and Spacer (2 sets) $10 each
11. Seat Belt Release Actuators (5) $10 each
12. Dash Surrounds (Grey 85-87, Blue) $20 each
13. Power Antennas (needs re-wind kit, 3) $25 each
14. Trunk Filler (piece between trunk and rear window) $20
15. Grille Springs (2) $15 set
16. Turbo Hood Ornament (NICE) $65
17. Rear Impact strip (not perfect but pretty nice shape) $25
18. Underdash Cover (Pass side) $10 each (will trade for a drivers side one)
19. Grey Pull Strap $10
20. 84 T Type Center Caps (3) $8 each
21. Bumper Support Mounts (dogbones with the studs to mount to bumper shocks, plastic) $10 pair
22. Vent (for under the column, vent only) $5
23.
24. OE Lug Nuts (86-87 GN, 11) $10 all
REAR END PARTS:
1. 8.5 4:56 Richmond Gear Set $100
2.
3. 8.5 3 series posi 28 spline unit has crack in the case that was fixed by GM but recracked. $50 (still works fine, could reweld or recase)
4. 8.5 axles 40k miles $50
F250 99-04 HID Headlight Kit with Harness ----$40
FILTERS, RANDOM:
WIX Oil 51258 $2
Baldwin Oil B9 $2
Puralator Oil L20033 $2
FRAM Oil PH2 $2
FRAM Oil CH9999 (2) $2 each
WIX/Rockhill Fuel 33296 $2
I will take the dash surround for the 84 if its for the GN. #12 interior parts.
#4 and #42 please. PM me the final amount with shipping (03064) and paypal addy. Thanks!
what does #2 include? pix please
Can I get a front and back pic of your nicest radiator cap?
Would you do $30 shipped for 2 of the #3's and the best one of the #13 in the O,B,I,C section?
Interested in these
4. SSBC Force 10 Dual piston front brakes with SSBC slotted rotors (basically new) $450
Also, need seat belt release
