Lot's of new/used part's
TURBOGTA1
Life is Sweet !!!
Bosch 65lb injector's low Z's with only 1200 break in miles, run perfect and look new and awsome with chrome bodys $290
brand new set of Comp cam hydr.roller lifters,#853's $295
brand new Metco rear upper adjustible control arms,and lower trailing arms
$475 for set,or will seperate if both sell
brand new GM cam sensors $140
1 slightly used GM cam sensor with a couple hundred miles and new o'ring
sensor like new $110
2 used gm cam sensors $50 each
cam sensor adjusting tool, $30
brand new GM egr solenoid controller $35
brand new GM S-shaped bypass heater hose $18
brand new GM coolant & washer tanks $35
brand new GM oil o'ring for filter housing $8
1 new GM center cap for 86-87 gn, $18
brand new aluminum rear end cover with cooling fins and GN logo,comes with gasket,and hardware $70
new 3" H.D intercooler blue hoses (2) $20
1 set of H.P push rods, a couple of hunderd miles on them, 8.700 $18
1 87 non turbo crank with rods, at standard, not damaged, make offer!!
42lb green stripe injectors $140
flex-lite heavy duty oil cooler with elect.fan,comes with h.d lines and fittings to tie into stock oil lines and mount under rad/bumper support. $90
precision adapter for oil filter relocator, screw on adapter and h.d fittings $25
34 MM front sway bar from T.A $45
vdo elect. temp and volt gauge,black face $15 each
1 86-87 GN rim,center cap and dunlop gt 235-60-15 tire with good meat,rim has some curb rash. great spare $85
4 gauge holder that mounts under radio in console $25
All price's plus shipping!!!!
E-mail me direct at Turbogta@aol.com
Interested in the 4 gauge pod for under radio. Never heard of a 4 gauge one for that location. pics?
Temp Guage
Interested in the electric VDO tempature guage. What kind of sender does it use or will it come with one? Maybe a picture of the guage? Use mclaigan@aol.com. Thanks.
Gauge holder sold, will have some pictures of all later!!
All the big stuff has to go, make reasonable offers!!! :eek:
Pictures sent, let me know you got them, had some file trouble.
All must go!!!!!!! make reasonable offers
Rear end cover, and oil cooler sold!!
All parts must go!!! make reasonable offers :D
