Lots of Parts for sale - New and Used (in CT)
2turboRX7
ALL PARTS HAVE BEEN SOLD!!
Pictures Here -> Pictures (If you see something in my pictures that isn't listed, ask if its still available)
86-87 Engine wire harness(no injector harness) $200 shipped
86-87 AC compressor $75
86-87 Belt tensioner $75 shipped
Turbo shield (2 - cut for downpipe, 1 - stock) $40 ea shipped
Front license plate bracket $20 shipped
Rear License plate bracket $20
Fuel Tank Straps with rubber strips $20 pr
Turbo crank(Std/Std but will need to be turned at most .010/.010) $250
Stock turbo inlet bell (2) $20 ea shipped
86-87 Upper intake(dog house) $30 shipped
86-87 throttlebody complete(sensors,throttle lever, vac manifold) $100 shipped
86-87 Up pipe $25 shipped
86-87 Water pump pulley (2) $25 ea shipped
86-87 Main accessory bracket (2) $70 ea
86-87 Y bracket on back of Alt $35 shipped
86-87 Power steering pump $70 shipped
Air Cleaner assembly(86-87) VG Condition $50 shipped
Alternator(86-87) (2) $60 ea SOLD
Balancer(Turbo harmonic balancer) $80 shipped
Battery cable guide(Small plastic guide that holds the posi bat cable to the lower front cover) (1) $20 shipped
Oil Cooler Adapter and lines (2) $30 ea shipped
Dip stick and tube(86-87 dipstick and tube) $50 shipped
Dip Stick tube (86-87) $15 shipped
Elbow (86-87 Turbo elbow) $25 shipped
Heads(stock 8445 heads needing rebuild) a set $50
Intercooler $45
Intercooler brackets both for $40
Motor mounts ( block Side) $35 shipped
Oil pan( 20 bolt Turbo oil pan) $40
Power steering pump (86-87) $70 shipped
Pulley (86-87 Water pump pulley) (2) $25 ea shipped
Posivitive Battery Cable Harness (1) $20 ea shipped
Negative Battery Cable Harness (1) $20 ea shipped
Fuel Lines (The Ones on Engine) $30 shipped
PowerMaster Its been of the car for 2 yrs. Motor acted up so I swapped it out for Vacuum $150
Oil Fill Tube and cap $10 SOLD
Stock Starter (2) $25 ea
Seat (87 GN Front Passenger, no rips) $175
Surround(Gauge surround) (2) $30 ea shipped
Grill 87 GN Grill (Good Condition) $150 shipped
Wheel well(Passenger Turbo plastic wheel well) $100
Transmission Torque Converter Inspection shield $20
Blackout wheel well moldings $60 ea
NOS GM Blackout Door Sweep (Passenger side) $75 shipped
GN Passenger side door w/PW, Remote mirror (Pickup only) $125
GN Center Console (Good Condition) $125 shipped
GN Center Console (VG Condition) $150 shipped
Lower Door Panels (both sides, no concert sound II) $60 pr
GN Spoiler (All 3 pieces) $130 shipped
NOS Turn signals (Both sides - Bumper lens) $100 pr shipped
Passenger side Blackout head light bezel NOS GM (New without box) $150 shipped
Passenger side Blackout Turn signal NOS GM (Headlight bezel signal) $40 shipped
Turn signals (both sides - bumper lenses) $40 pr shipped
Console shifter plate $25 shipped
86/87 Injector Harness $40 shipped
NOS Bumper bumperette strips (New in Box GM) x 2 $25 ea shipped
Grey Guage Surround (VG Condition) $50 shipped
Grey Guage Surround (GoodCondition) $35 shipped
Radio Bezel (2) $30 ea shipped
Guage Bezel (2) One has an alarm LED in it. $50 ea shipped
Grey Arm Rests $10 ea
MORE PARTS FOUND!!!
Adjustable WasteGate Actuator (threaded no end) (2) $40 ea. shipped
86-87 Center Caps (7) $20 ea
Washer fluid tank (2) $10 ea
Seat belt loops $20 pr
S Hoses (good condition) (3) $10 ea
Third Brake Light $ 15
Hood Shocks (used) $15pr
Hood shocks (new) $30pr shipped
86-87 stock header driver side has crack $30
86-87 Stock header passenger side $90
Visors $20 pr
Shifter w/cable $50 shipped
86-87 Fuel Rails (3) $30 ea shipped
86-87 Crank Pulley (2) $25 ea
Wiper motor $30
'87 Computer $50 shipped
EGR Cover $10
86-87 coil pack bracket (horse shoe one) $25
Throttle pedal $25 shipped
Black pull straps $30 pr shipped
MAF Hoses (2) $15 ea
Computer plastic (2) $15 ea
Glove Box $20
Radiator Hose (upper GM) $20
Under Dash Plastic $20
Fuel Pump HOT WIRE KIT (used) $40
86-87 Intercooler Fan $50 shipped
86-87 Throttle Bracket $45 shipped
Bumper Strip
Hood molding
Rear Seat - Lower and Back Cushion
AC Lines (2)
MORE PARTS YET TO COME.
If they are the Front Bumperrette strips I'll take both. Let me know. Any pictures or part numbers.
I replied back to the emails sent.
Also I uploaded more pictures and added more parts! Can't believe how much stuff I have.
TRICKSIXPA - Bumperettes are GM # 25505972
Signal Lamps are GM # 918731 LH and 918732 RH
I'll check on wheel well moldings tomorrow.
Dalton - I'll get back to you on tensioner, someone inquired about it earlier.
Thank You!
I'll pass on the bumperetts how much are you asking for the drive shaft loop? Do you happen to have a fixed antenna base?
Do you still have the intercooler brackets and the elbow from the intercooler to the throttle body.
Jason85gn - I checked them out tonight. There are no dents on the outside of the moldings. There was a small dent up on the inside but would only be seen if looking up inside the wheel well. Here is a direct link to the picture. http://i237.photobucket.com/albums/ff38/TurboZV6/WheelMolding_zps5bb6d1ae.jpg
I have a driver and passenger front. They are used so you may want to give them a coat of paint. Let me know if you're interested.
Chuck - No cooling fan
Thanks, Keith
PMs and paypal sent.
confirm when shipped please
