- Jun 6, 2001
Parts for 86-87 Buick GN:
1. Stock 2004R transmission pan w/bolts and drain plug.
2. Stock GN 20 bolt oil pan.
3. Stock turbo heat shield.
4. Chrome rear-end cover w/bolts and drain plug.
5. Stock cross-over pipe in excellent condition.
6. GReddy Profec B-Spec 2 boost controller works perfectly.
7. Stock intake flexible air tube.
8. Stock (Kirbans) oil cooler lines.
9. Stock fuel line (frame connection to FPR).
10. New brake line (curly one, goes from master cylinder to proportion valve)
11. Steel braided line, attaches to fuel rail then to fuel pressure gauge (Qty, 2)
12. Rail fuel pressure gauge (direct bolt-on)
13. Factory vacuum block (fits onto to top of plenum).
14. 120 amp A/C Delco alternator.
15. Manual boost controller.
16. Small hard lines which attach to the trans lines then to radiator, new.
17. Turbo oil line (goes from top of turbo to oil fitting in block, Kirban replacement part.
18. Comp cams 853-12 hyd. Roller lifters, have 5, I tossed out the 6th one as it made a noise, the 5 I have work perfectly.
19. IAC factory housing w/bolts.
20. GM new motor mount, labeled as RH, part# 1258718.
21. GNX body bushings.
22. New GM timing chain/gears. Comes with factory tensioner/spring and new bolts.
23. Stock factory valve cover bolts.
24. Hotchkis passenger side heat shield.
25. Engine tie-down (ratchet type).
26. Silicon hoses for intercooler connections, I have a blue set and a black set. The blue set has two 2.5”x2.5”, one 2”x2” and one 3”x3”. The black set has two 2.5”x3”: 3”L and one 2.5”x3”: 4”L.
27. Rubber tube for Big-Mouth intake system with air temp sensor, size is 3” one side and 4” other side.
28. Valve cover breather, 2 Moroso and 2 Kenne Bell, push-in. I have 3 rubber inserts and 2 insertion sleeves ( for aftermarket valve covers). Also have the small breather that is made to fit the stock valve cover between turbo and valve cover.
29. Set of 6 MSD 50lb. injectors with 3 Turbo Tweak chips, Emissions chip and a 5.6 and 6.0 alcohol chips. Injectors have 12K miles and were ultrasonic cleaned by Casper’s (waste of my money as they were in perfect working order).
30. Precision HD wastegate, came on my TE-63E turbo, used for 100 miles.
31. Canton radiator overflow tank w/mounting clamp, size is 6”L and 2.75” diameter.
32. New fiberglass bumper filler, driver’s side rear.
If I were to include pics of everything the post would be too large, email me and I will send pics of anything listed. Make reasonable offer on items and let me know what state you are in and we can work out the shipping. Paypal works well for me.
Mike
Mike
