I was wondering if there are any glaring reasons a car with my set up would run good 60 ft, fair e.t's but a slow MPH? Car leaves hard but doesnt seem to MPH like I think it should. I only have a scanmaster, so I cant go over all the data like I would like. But, O2 never dropped below .789, no knock by either scanner or alarm, car sounded good, not breaking up or anything.
See sig for mods, running new valve springs. 52 lbs fuel pressure. 28 lbs boost! I know the boost sounds way high but I tried with 2 different boost gauges with same results.
Could too much boost with stock innercooler cause this? Again, no knock so I'm confused.
My best 1/8 & 1/4 were 91 & 115 mph but usually more like 89 & 111 mph.
Ets 7.5 & 11.8 avg.
Some things not in sig, translator with LS1 MAF. Cold air kit. Electric cutout, (same et's, mph with it open or closed.) 62 mm TB. My TT chip is the old kind thats not adjustable, so timing is set at 24 degrees.
When I installed cam,(Poston grind# GN107T, part # 107degree lc- 4degree adv)) it said "Timing data is shown at 4 degrees advanced. I set it with dots aligned, didnt do any cam timing. (didnt know how) Heres specs, shows 430/430 lift on spec sheet but 269/269 on graph? 254/254 duration on spec sheet & 202/202 on graph? 0 overlap, Could not doing cam timing properly cause lots of torque but poor HP? I know I'm asking a lot, but maybe somone has seen this before. I got the feeling I'm going to be pulling the cam back out & setting up properly. Thanks.
Ets 7.5 & 11.8 avg.
