There is no way to turn on open loop idle on with a tt chip. It is activated after the car is initially warmed and driven.
From 6.1 chip manual.
This chip utilizes an open loop idle mode for smoothness. The first time the car is run after the ECM is reset, open loop idle mode will not be enabled. This is to allow the BLM’s to learn quicker. Once the car is warmed up and driven around, the next time the car is started, open loop idle will be enabled for a smoother idle. The A/F ratio will typically be in the 12.5-13.5 range at idle
So this is where your BLM got set. Seems like he added fuel to the chip and the initial idle learning cycle pulled fuel to set it back to 14.7:1. Why did you dump your Gen II translator for a gen 1? If you go back to that, you can let it learn, go OL, then fatten it up from there.
