streetknight
DCVING
- May 26, 2001
OK guys, been chasing a skip in this car that's 100% stock. Turned out to be a bad injector. I had a spare set of Blue Tops and a Red Armstrong RA93 chip I put in today and now the car runs great, but noticed the BLM's are in the mid to high 90's while cruising. The o2 voltage was 950mv (using an OTC4000e) @ WOT.
I also put an adjustable FP regulator on it when I did the injectors, FP is 43# line off.
The fuel pump was recently replaced with a stocker, which I recommended they need to change to a Walbro or something comparable. I noticed @ WOT the FP on the gauge started to drop. The car has the stock NON adjustable actuator on it and NO boost gauge, so I have no clue where boost is.
Any ideas?
Any ideas?
