Is it possible that running a stock turbo all out on a stroker engine with good heads could cause knock? Alky make it worse from being too rich? This setup will only make 15psi of boost but I'm wondering if the stock snail is too far past an efficiency range at this point to work and overheating the intake charge or something. Been working on this car for a while, but now I just can't make it work right for a guy. Thought alky would help, but it acts the same. Checking the basics and starting from scratch in the spring, but just curious on thoughts. Bigger turbo is not in the budget right now.
