low boost ?
Pat Adkins
:mad: car will only build 1-2 #s boost on foot brake & very slow to spool on a roll I know there is not a leak between header & turbo since I just replaced with a composite gasket. This is a Ta49 with a 2800 stall. adjustable rod turned all the way in I get only 10#s of boost open bleeder & it will not go above 16#s:confused:
I'd guess the puck ain't closing properly over the ported hole in the turbo. :(
It could be alot of things. Cracked headers come to mind. Vacuum leaks as well. also, if you are running a race chip it is usually so rich down low that it affects spool-up. Did that to my car anyways.
Reds 93 chip
vacuum is @ 15hg at idle does this seem low?
I had crossover pipe off recently & I don't know if that should be an issue.
acuator opens @8 psi
NEARING,
My buddy (Pat Adkins) has made several changes to the car but nothing that would affect building boost at the line...it builds boost alright from a roll....if I stomp on it from a dead dig it takes nearly forever for the boost to kick in is what i'm feeling....
T
