- Aug 1, 2003
with that plug for the translator maf plus at the ign module white wire pin A disconnected the white wire is open ... ecu goes into bypass mode (code 42 will set ) . you should have seen the check engine light (SES) to tell you there was a problem
with the code 42 it runs off the small calpak chip . resulting in base base timing and default fueling..problem is the default fueling is for stock injectors , if you have larger injectors say 60s the fueling will be double what it should be ,extremely rich and would explain glowing manifolds and would have a hard time running on that much fuel and may have even fouled a couple plugs which would explain a low vacuum due to missing cylinder(s)
you should have noticed the SES lamp on startup and stopped at that point
now with the connector on A (white wire) looped ..clear the code .. check the plugs are clean and try again
