billygeg
- Oct 5, 2009
Hey Guys, I just installed a Dakota dash and noticed today the digital screen was blinking under the speedo indicating low oil pressure.. It fluctuated from around 7 to 9 at idle with car warm but once I stepped on the gas it went up to about 10 lbs for 1000 rpm..I read a few threads prior to posting and it appears these cars run on low oil pressure at idle (around 10 psi) so Im not sure if I have something to worry about...
I also seen other threads mentioning a leaky head gasket and oil in water which would cause that problem, so I ran right to my garage to check...The oil level appears fine but the antifreeze in my reservoir seems a little tinted brown..The antifreeze in my radiator is green so do I have anything to worry about? Im hoping maybe the discolored antifreeze in the reservoir is maybe cause by old residue that was already in the reservoir to begin with...
