So today I took the GN out and I noticed that it appears the alky pressure is low. The led didn't turn green until 5 psi higher than it normally does and won't turn green when I hit the test button. I'll check for anything in the check valve and will check the voltage when I hit the test button, but what else could it be? I just had the pump rebuilt by Julio less than a year ago.
