Hi,
I am about to replace my factory LCA's with a set of boxed UMI's and had a look to see what is needed to be done.
I noticed the bolt that secured the arm to the frame at the front of the control arm goes through into the frame. Even with the access hole in the frame adjacent, it looks kinda tough to get a wrench on to the head of the bolt.
Do these bolts need to be entirely removed, or does the LCA just slide off of it once all the other fasteners are removed?
I am sure this procedure has been performed by numerous members, so can someone quickly fire me off a couple of tips, please?
Jim
Jim
